Rudy, thank you for your input also but I'm not quite sure what you meant. Do you mean that I should look at the ADC values in the code and possibly alter them?
Regards to both of you
Dermot
Explore... Chat... Share...
btidey wrote:Here is one suggestion for the loop codeCode: Select all#define ON_THRESHOLD 500
#define OFF_THRESHOLD 400
int adcVal;
int state = -1;
adcVal = analogRead(A0);
if(adcVal >= ON_THRESHOLD) {
setSwitchOn();
} else if(adcVal <= OFF_THRESHOLD) {
setSwitchOff();
delay(10);
void setSwitchOn() {
if(state != 1) {
mySwitch.send("100111101111101000001111");
state = 1;
void setSwitchOff() {
if(state != 0) {
mySwitch.send("100111101111101000001110");
state = 0;
ADC range is 0 - 1024 . I suggest having different thresholds for on and off otherwise if the value was near the middle then it could toggle on and off due to adc noise. These are put into #defines which are just a more readable way of setting their values. state was initialised to -1 so that the first call to switchOn or switchOff is always actioned to set the state accordingly.
