By Remvs
#87648 Hi there!
I have a Wemos D1 Mini with an NTC and voltage divider. I have elaborate code that runs fine when the Wemos is stand alone and attached to my PC's USB. I also have a battery shield attached to a 3,7 LiPo battery. Whenever I hook this up to the Wemos D1 I observe the following behavior.
- First boot goes fine.
- After a few seconds I do a reset or interrupt the power and then the boot fails with:
Code: Select allFatal exception (0):
epc1=0x40100003, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
    I have tripple checked the solderings and tried pulling Hi GPIO0 and GPIO2, this aside from GPIO15 which I pulled low already.
    I have used different sets of hardware, to no avail.
Please see attached a schema and a picture for reference.
    Green wire is pulling GPIO15 low
    Battery + is connected to shield out of view via underside of shield, minus can be seen
    Purple wires is NTC.
Any suggestions would be very much appreciated.
By Remvs
#87665 Hi Davy,
Thanks, that sounds like something for me to explore. However, and I didn't mention this earlier: When i connect the ESP to USB/PC and I hook up the battery shield; i get the same erroneous behavior.
on your suggestion & as I am not an electronics guy by education; You are referring to a capacitor over input from battery into batt. shield, right? any suggestions on size (F)? Will investigate myself as well
Thanks a lot!
davydnorris wrote:I suspect the initial boot up current draw is pulling your LiPo voltage too low.
Put a big fat capacitor in there as a buffer for the initial spike and see how you go
By pangolin
#87822 Why repeated mentions of GPIO15? Its GPIO0 that controls booting or flashing. Yes 15 is involved and needs to be at the correct level too, but I have never know anybody have any problems with gpio15 when leaving it alone.
Google "ESP8266 boot pins" and make sure you are fully aware of the function of each.
