By espDino
#87911 Hello!
Please help, how I can connect to ESP8266 from PC via python program?
I have this program loaded in ESP8266:
Code: Select all#include "ESP8266WiFi.h"
const char* ssid = "home_wifi";
const char* password =  "12345678";
WiFiServer wifiServer(5684);
byte message_buffer[10];
int data_index;
int client_count;
  delay(1000);
  WiFi.begin(ssid, password);
    delay(1000);
    Serial.println("Connecting..");
  Serial.print("Connected to WiFi. IP:");
  wifiServer.begin();
  client_count = 0;
void loop()
  WiFiClient client = wifiServer.available();
  //Serial.println("čekám");
  while(!(client = wifiServer.available())){}
    if(client.connected())
      Serial.println("Client Connected");
    while(client.connected()){
      while(client.available()>0){
        // read data from the connected client
        Serial.write(client.read());
      //Send Data to connected client
      while(Serial.available()>0)
        client.write(Serial.read());
    client.stop();
    Serial.println("\nClient disconnected");
When I connect to ESP via Putty, Serial monitor prints correctly "Client Connected" (and then data, which I send and after closing Putty "Client disconnected").
But problem is, when I run my Python program:
Code: Select allimport socket
HOST = '192.168.1.6'  # The server's hostname or IP address
PORT = 5684
s=socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect((HOST, PORT))
s.sendall(b'Hello, world')
s.close()
ESP8266 only sometimes register this coming socket...I must run my python program several times to have same result as when I connect to ESP8266 via putty...
Where is problem?
Please help! :)
