In a nutshell, I occasionally see time jump around wildly across several syncs (offset>=-4295s) before coming back. In the log below (taken from mqtt output), the two nodes are reporting back their sntp return values via mqtt, so the timestamp on the left is local linux time (accurate). I have manually confirmed that the output of rtctime.get() jumps around on these nodes when the ntp offset is large. There are usually only a couple of strange offsets before time returns to normal, but in the case below it lasted several hours before returning (back to normal @ ~13:25).
Jul 28 06:29:01 node2/debug sntp sync success: curr=1595917741s offset=25086us server=192.168.2.1 delay=4226us
Jul 28 06:29:14 node1/debug sntp sync success: curr=1595917754s offset=27651us server=192.168.2.1 delay=4333us
Jul 28 06:45:42 node2/debug sntp sync success: curr=1595918742s offset=-4295s server=192.168.2.1 delay=112731us
Jul 28 06:45:54 node1/debug sntp sync success: curr=1595918754s offset=110634us server=192.168.2.1 delay=3952us
Jul 28 07:02:26 node2/errors sntp sync failed! (pre-MQTT) type=4 err=nil
Jul 28 07:02:39 node1/errors sntp sync failed! (pre-MQTT) type=4 err=nil
Jul 28 07:19:01 node2/debug sntp sync success: curr=1595920741s offset=-8590s server=192.168.2.1 delay=6423us
Jul 28 07:19:14 node1/debug sntp sync success: curr=1595920754s offset=-4295s server=192.168.2.1 delay=4165us
Jul 28 07:35:41 node2/debug sntp sync success: curr=1595921741s offset=-111417us server=192.168.2.1 delay=4898us
Jul 28 07:35:54 node1/debug sntp sync success: curr=1595921754s offset=-4295s server=192.168.2.1 delay=3631us
Jul 28 07:52:22 node2/debug sntp sync success: curr=1595961395s offset=-184899us server=192.168.2.1 delay=313262us
Jul 28 07:52:34 node1/debug sntp sync success: curr=1595927049s offset=-4296s server=192.168.2.1 delay=4928us
Jul 28 08:09:01 node2/debug sntp sync success: curr=1595923741s offset=-42949s server=192.168.2.1 delay=3463us
Jul 28 08:09:14 node1/debug sntp sync success: curr=1595923754s offset=-4295s server=192.168.2.1 delay=3753us
Jul 28 08:25:46 node2/errors sntp sync failed! (pre-MQTT) type=4 err=nil
Jul 28 08:25:59 node1/errors sntp sync failed! (pre-MQTT) type=4 err=nil
Jul 28 08:42:21 node2/debug sntp sync success: curr=1595925741s offset=-4295s server=192.168.2.1 delay=3601us
Jul 28 08:42:34 node1/debug sntp sync success: curr=1595925754s offset=-8590s server=192.168.2.1 delay=62850us
Jul 28 08:59:01 node2/debug sntp sync success: curr=1595926741s offset=-4295s server=192.168.2.1 delay=3936us
> for k,v in pairs(node.info("sw_version")) do print (k,v) end
git_branch master
git_release 3.0-master_20200610
git_commit_id 8d091c476edf6ae2977a5f2a74bf5824d07d6183
node_version_minor 0
git_commit_dts 202006092026
node_version_revision 0
node_version_major 3
> for k,v in pairs(node.info("build_config")) do print (k,v) end
ssl true
number_type float
modules adc,bit,dht,file,gpio,i2c,mqtt,net,node,ow,rtcmem,rtctime,sntp,spi,tls,tmr,uart,wifi,ws2801,ws2812,ws2812_effects
lfs_size 0
Server is openwrt, CHAOS CALMER (15.05.1, r48532) busybox ntpd.
