I have here a wemos D1 mini pro which I use already about 2 month. Till now I had no problem with programming.
After I tried a sketch and would like to upload an other sketch I will get now the following error:
Arduino: 1.8.13 (Windows 10), Board: "LOLIN(WEMOS) D1 mini Pro, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 16MB (FS:14MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
Executable segment sizes:
IROM : 309432 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 27760 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1280 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1888 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25600 ) - zeroed variables (global, static) in RAM/HEAP
Der Sketch verwendet 340360 Bytes (32%) des Programmspeicherplatzes. Das Maximum sind 1044464 Bytes.
Globale Variablen verwenden 28768 Bytes (35%) des dynamischen Speichers, 53152 Bytes für lokale Variablen verbleiben. Das Maximum sind 81920 Bytes.
esptool.py v2.8
Serial port COM4
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: f4:cf:a2:d8:43:99
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
File "C:\Users\privat\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/privat/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 2916, in main
esp.change_baud(args.baud)
File "C:/Users/privat/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 104, in inner
return func(*args, **kwargs)
File "C:/Users/privat/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 705, in change_baud
self.command(self.ESP_CHANGE_BAUDRATE, struct.pack('<II', baud, second_arg))
File "C:/Users/privat/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 347, in command
p = self.read()
File "C:/Users/privat/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 292, in read
return next(self._slip_reader)
File "C:/Users/privat/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 2045, in slip_reader
raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
The connection to my port is ok.
When I press the reset button on the wemos I will get the following message:
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
Hope somebody can help me how I can program again my wemod D1.
kindly regards for any answer.
