So I have an Arduino Nano which is the master and it will be sending data to WeMos D1 Mini, but the example is not working what so ever.
Here is the code I'm using from "Arduino IDE 1.8.13" using the "ESP8266 core 2.7.4", it is the example code named "slave_receiver":
// Wire Slave Receiver
// by devyte
// based on the example by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Receives data as an I2C/TWI slave device
// Refer to the "Wire Master Writer" example for use with this
// This example code is in the public domain.
#include <Wire.h>
#define SDA_PIN 4
#define SCL_PIN 5
const int16_t I2C_MASTER = 0x42;
const int16_t I2C_SLAVE = 0x08;
Serial.begin(115200); // start serial for output
Wire.begin(SDA_PIN, SCL_PIN, I2C_SLAVE); // new syntax: join i2c bus (address required for slave)
Wire.onReceive(receiveEvent); // register event
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(size_t howMany) {
(void) howMany;
while (1 < Wire.available()) { // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
Any alternatives, working examples?
Thanks.
