By loloToster
#90242 HI,
I want to make custom hardware monitor for my pc and im struggling with an issue. When I upload my code it doesnt work properly, it stops in a random place, led on wemos starts blinking and it transmit some stuff via serial:
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Soft WDT reset
>>>stack>>>
ctx: cont
sp: 3ffffce0 end: 3fffffc0 offset: 01a0
3ffffe80: 00000000 00000000 3ffefc88 40202d28
3ffffe90: 3ffefd38 3ffffeb0 0000007c 402041db
3ffffea0: 3ffefc88 000000ef 3ffefc88 40201ca3
3ffffeb0: 40000000 3ffefc80 3ffffeee 4020269c
3ffffec0: 00000032 3ffefca8 3ffefc88 40201ed5
3ffffed0: 00000000 0000002d 0000002d 00000000
3ffffee0: 00000000 3ffefca8 3ffefc88 402020f3
3ffffef0: 00000000 00000000 3ffefc88 40202b90
3fffff00: 3ffefc88 00000000 00000103 40202e71
3fffff10: 00f42400 7fced068 3ffefc88 4020266c
3fffff20: 3ffe84cc 00000000 3ffefc88 40201078
3fffff30: 000000f0 00000140 00000001 40202075
3fffff40: 00000000 014000f0 00000001 3ffefdc0
3fffff50: 3ffe84cc 00000000 3ffefc88 402010cf
3fffff60: 00f42400 7fced8d7 3ffefc88 40203b02
3fffff70: 00000000 00000033 80fefc88 402035c0
3fffff80: 00000000 00000000 00000001 40100154
3fffff90: 3fffdad0 00000000 3ffefd80 3ffefdc0
3fffffa0: 3fffdad0 00000000 3ffefd80 40204d14
3fffffb0: feefeffe feefeffe 3ffe84ec 40100bed
<<<stack<<<
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
But when i start python program that is connecting to wemos everything works. I dont want to use wemos wifi capabilities, I use it because it is faster then for examle arduino nano and it works with 3v3.
Here is my arduino IDE code:
Code: Select all#include <SPI.h>
#include "Ucglib.h"
#define TIME_TO_DISCONNECT 4000
#define DELAY 100
#define MINI_FONT ucg_font_7x13r  //ucg_font_7x13r   ucg_font_helvB12r
#define DEFAULT_FONT ucg_font_helvB24r
//Ucglib_ILI9341_18x240x320_SWSPI ucg(/*sclk=*/ 13, /*data=*/ 11, /*cd=*/ 9 , /*cs=*/ 5, /*reset=*/ 8);
Ucglib_ILI9341_18x240x320_HWSPI ucg(/*cd=*/ 5 , /*cs=*/ 15, /*reset=*/ -1);
//Ucglib_ILI9341_18x240x320_HWSPI ucg(/*cd=*/ 9 , /*cs=*/ 5, /*reset=*/ 8);
byte CPUtemp = 0;
byte GPUtemp = 0;
float RAMload = 0;
//byte RAMloadI;
byte cpuRGB[] = {0, 255, 0};
byte gpuRGB[] = {0, 250, 255};
byte ramRGB[] = {40, 180, 255};
byte preGPUtemp;
byte preCPUtemp;
float preRAMload;
int countDis;
boolean startUpWhenCon = false;
boolean startUpWhenDis = true;
  pinMode(2, OUTPUT);
  digitalWrite(2, HIGH);
  delay(1000);
  ucg.begin(UCG_FONT_MODE_SOLID);
  ucg.setRotate180();
  ucg.setColor(255, 255, 255);
  //ucg.clearScreen();    //this should be uncommented but wemos get stuck on it and wont go further
  ucg.setFont(MINI_FONT);
  drawMiniCPUicon();
  drawGPUicon();
  drawRAMicon();
  ucg.setFont(DEFAULT_FONT);
  if (Serial.available() > 0) {
    String s = Serial.readString();
    preCPUtemp = CPUtemp;
    preGPUtemp = GPUtemp;
    preRAMload = RAMload;
    if (startUpWhenCon) {
      ucg.setColor(0, 0, 0);
      ucg.drawBox(60, 65, 189, 155);
      drawMiniCPUicon();
      drawGPUicon();
      drawRAMicon();
    countDis = 0;
    if (s.length() > 4) {
      CPUtemp = s.toInt();
    } else if (s.length() > 2) {
      RAMload = s.toFloat();
    } else {
      GPUtemp = s.toInt();
    byte mappedCPUtemp = map(CPUtemp, 10, 100, 239, 0);
    byte mappedGPUtemp = map(GPUtemp, 10, 100, 239, 0);
    byte mappedRAMload = map(RAMload * 10, 0, 170, 239, 0);
    //////////CPU/////////////////////////////////////////////////////////////////////////
    if (CPUtemp >= 10 && CPUtemp < 100 && preCPUtemp != CPUtemp)
      updateInfo(0, mappedCPUtemp, cpuRGB, CPUtemp);
    //////////GPU/////////////////////////////////////////////////////////////////////////
    if (GPUtemp >= 10 && GPUtemp < 100 && preGPUtemp != GPUtemp)
      updateInfo(80, mappedGPUtemp, gpuRGB, GPUtemp);
    //////////RAM/////////////////////////////////////////////////////////////////////////
    if (RAMload > 0 && preRAMload != RAMload) {
      columns(160, mappedRAMload, ramRGB);
      if (RAMload < 10) {
        ucg.setPrintPos(165, mappedRAMload - 6);
        ucg.print(RAMload, 1);
        printGB(mappedRAMload, 217);
      } else {
        ucg.setPrintPos(168, mappedRAMload - 6);
        ucg.print(RAMload, 0);
        printGB(mappedRAMload, 211);
  } else if (countDis >= TIME_TO_DISCONNECT) {
    if (startUpWhenDis) {
      CPUtemp = 0;
      GPUtemp = 0;
      RAMload = 0;
      ucg.clearScreen();
      drawSleepingToster();
      startUpWhenDis = false;
      startUpWhenCon = true;
    sleepingAnimation();
  } else {
    countDis++;
    delay(1);
//funkcje/////////////////////////////
void updateInfo(byte x, byte mappedValue, byte rgb[], byte temp) {
  columns(x, mappedValue, rgb);
  ucg.setPrintPos(x + 5, mappedValue - 6);
  ucg.print(temp);
  ucg.print(" C");
  ucg.drawDisc(x + 45, mappedValue - 26, 4, UCG_DRAW_ALL);
  ucg.drawDisc(x + 45, mappedValue - 26, 1, UCG_DRAW_ALL);
void columns(byte x, byte mappedValue, byte rgb[]) {
  ucg.setColor(0, 0, 0, 0);
  ucg.drawBox(x, 0, 80, mappedValue + 1);
  ucg.setColor(0, rgb[0], rgb[1], rgb[2]);
  for (byte i = 239; i > mappedValue; i--) {
    ucg.drawHLine(x, i, 80);
void sleepingAnimation() {
  //poczatkowa/nizsza  pozycja
  ucg.drawBox(137, 98, 7, 7);
  ucg.drawBox(137, 94, 7, 4);
  delay(DELAY);
  ucg.setPrintPos(147, 100);
  ucg.print("z");
  delay(DELAY);
  ucg.setPrintPos(167, 95);
  ucg.print("Z");
  ucg.drawBox(167, 66, 20, 4);
  delay(DELAY);
  //wyzsza pozycja
  ucg.drawBox(137, 94, 7, 7);
  ucg.drawBox(137, 101, 7, 4);
  delay(DELAY);
  ucg.setPrintPos(147, 96);
  ucg.print("z");
  delay(DELAY);
  ucg.setPrintPos(167, 91);
  ucg.print("Z");
  delay(DELAY);
void drawSleepingToster() {
  ucg.drawRBox(61, 115, 118, 81, 19);
  ucg.drawBox(61, 134, 30, 70);
  ucg.drawBox(149, 134, 30, 70);
  ucg.drawBox(179, 142, 8, 7);
  ucg.drawBox(84, 119, 73, 5);
  ucg.drawRBox(86, 151, 22, 8, 1);
  ucg.drawRBox(132, 151, 22, 8, 1);
  ucg.drawRBox(113, 171, 14, 6, 1);
  ucg.setPrintPos(61, 218);
  ucg.print("// No Signal...//");
void printGB(byte mappedValue, byte x) {
  //G
  ucg.drawDisc(x, mappedValue - 13, 6, UCG_DRAW_ALL);
  ucg.drawDisc(x, mappedValue - 13, 3, UCG_DRAW_ALL);
  ucg.drawTriangle(/*right*/224, mappedValue - 13 ,/*top*/ 224, mappedValue - 25,/*mid*/ 216, mappedValue - 13);
  ucg.drawBox(x, mappedValue - 13, 4, 2);
  //B
  ucg.drawRBox(x + 9, mappedValue - 19, 9, 8, 3);
  ucg.drawRBox(x + 9, mappedValue - 14, 9, 8, 3);
  ucg.drawRBox(x + 10, mappedValue - 17, 5, 4, 1);
  ucg.drawRBox(x + 10, mappedValue - 12, 5, 4, 1);
  ucg.drawBox(x + 9, mappedValue - 19, 3, 13);
void drawRAMicon() {
  ucg.setColor(ramRGB[0], ramRGB[1], ramRGB[2]);
  ucg.drawBox(160, 240, 80, 80);
  ucg.drawBox(169, 262, 62, 27);
  ucg.drawRBox(160, 266, 12, 5, 1);
  ucg.drawRBox(228, 266, 12, 5, 1);
  ucg.drawBox(175, 267, 9, 14);
  ucg.drawBox(188, 267, 9, 14);
  ucg.drawBox(201, 267, 7, 14);
  ucg.drawBox(211, 267, 4, 6);
  ucg.drawBox(211, 275, 4, 6);
  ucg.drawBox(218, 267, 7, 14);
  for (byte i = 172; i < 200; i += 4) {
    ucg.drawFrame(i, 288, 4, 5);
  for (byte i = 204; i < 227; i += 4) {
  ucg.setPrintPos(160, 236);
  ucg.print("Init...");
void drawGPUicon() {
  ucg.setColor(gpuRGB[0], gpuRGB[1], gpuRGB[2]);
  ucg.drawBox(80, 240, 80, 80);
  ucg.drawRBox(89, 257, 61, 40, 8);
  ucg.drawBox(89, 257, 20, 40);
  ucg.drawBox(85, 254, 7, 3);
  ucg.drawBox(89, 257, 3, 46);
  for (byte i = 106; i < 137; i += 4) {
    ucg.drawFrame(i, 296, 4, 5);
  ucg.drawLine(123, 300, 124, 300);
  ucg.drawDisc(106, 276, 12, UCG_DRAW_ALL);
  ucg.drawRBox(122, 268, 19, 6, 1);
  ucg.drawRBox(122, 281, 19, 6, 1);
  ucg.drawRBox(103, 274, 7, 7, 1);
  ucg.setPrintPos(80, 236);
void drawMiniCPUicon() {
  ucg.setColor(cpuRGB[0], cpuRGB[1], cpuRGB[2]);
  ucg.drawBox(0, 240, 80, 80);
  for (byte i = 12; i < 40; i += 12) {
    ucg.drawRBox(13, i + 253, 54, 6, 2);
    ucg.drawRBox(i + 13, 253, 6, 54, 2);
  ucg.drawRBox(19, 259, 42, 42, 2);
  ucg.setColor(0, cpuRGB[0], cpuRGB[1], cpuRGB[2]);
  ucg.drawRBox(25, 265, 30, 30, 2);
  ucg.drawRBox(31, 271, 18, 18, 2);
  ucg.setPrintPos(0, 236);
/*void drawBigCPUicon() {
  ucg.drawBox(0, 239, 79, 80);
  ucg.setColor(0, 255, 255, 255);
  for (int i = 12; i < 50; i += 12) {
    ucg.drawRBox(7, i + 247, 66, 6, 2);
    ucg.drawRBox(i + 7, 247, 6, 66, 2);
  ucg.drawRBox(13, 253, 54, 54, 2);
And here my python code:
Code: Select allimport serial
import time
import wmi
import math
global w
w = wmi.WMI(namespace="root\OpenHardwareMonitor")
global cpu
global gpu
global ram
def getRamSize():
    used = 0
    free = 0
    hw_infos = w.Sensor()
    for sensor in hw_infos:
        if sensor.SensorType==u'Data':
            if sensor.Name == u'Used Memory':
                used = int(math.ceil(sensor.Value))
            elif sensor.Name == u'Available Memory':
                free = int(math.ceil(sensor.Value))
    return used + free
def updateHWData():
    global w
    global cpu
    global gpu
    global ram
    cpu = []
    gpu = []
    ram = []
        #print (sensor.SensorType)
        #print(sensor.Name)
        #print(sensor.Value)
        if sensor.SensorType==u'Temperature':
            if sensor.Name == u'CPU Package':
                cpu.insert(0,  "000%d" % sensor.Value)
            elif sensor.Name == u'GPU Core':
                gpu.insert(0,  "%d" % sensor.Value)
  #    if sensor.SensorType==u'Clock':
   #         if sensor.Name == u'CPU Core #1':
    #            cpu.insert(1,  "CPU clk: %dMHz" % sensor.Value)
     #       elif sensor.Name == u'GPU Core':
      #          gpu.insert(1,  "GPU clk: %dMHz    " % sensor.Value)
                ram.insert(0,  "%.1f" % sensor.Value)
def serial_ports():
    ports = ['COM%s' % (i + 1) for i in range(256)] #['COM%s' % (i + 1) for i in range(256)] / ['COM%s' % (i + 1) for i in range(0,8,7)] dla COM8
    result = []
    for port in ports:
        try:
            s = serial.Serial(port)
            s.close()
            result.append(port)
        except (OSError, serial.SerialException):
            pass
    return result
arduino = serial.Serial(serial_ports()[1], 115200, timeout=.7)
#arduino = serial.Serial('COM8', 9600, timeout=.7)
time.sleep(2)
arduino.write("start".encode())
time.sleep(0.5)
while len(w.Sensor()) < 1:
    time.sleep(1)
cpu = []
gpu = []
#ram = ["RAM total: {:2d}GB ".format(getRamSize())]
while True:
    #startTime = int(round(time.time() * 1000))
    for i in range(4):
        updateHWData()
        arduino.write(cpu[0].encode())
        time.sleep(3)
        arduino.write(gpu[0].encode())
        time.sleep(3)
        arduino.write(ram[0].encode())
        time.sleep(3)
Everything works with arduino nano and i dont understand why not with wemos. Please help me.
