Im new to ESP8266 im trying to run one of my first programs from this site:
https://highvoltages.co/iot-internet-of ... mqtt/#Code
I installed all libaries, connected ESP8266 and installed driver. I got this error:
Arduino:1.8.16 (Windows 10), Płytka:"Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from c:\users\marcin\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\assert.h:10,
from c:\users\marcin\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\sys\reent.h:503,
from c:\users\marcin\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\stdlib.h:18,
from c:\users\marcin\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\cstdlib:75,
from c:\users\marcin\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\stdlib.h:36,
from C:\Users\Marcin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Arduino.h:27,
from sketch\8266kod_v1.ino.cpp:1:
C:\Users\Marcin\Documents\Arduino\libraries\WhareHauoraWiFiManager/WiFiManager.h:25:24: error: 'const char HTTP_HEAD []' redeclared as different kind of entity
25 | const char HTTP_HEAD[] PROGMEM = "<!DOCTYPE html><html lang=\"en\"><head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1, user-scalable=no\"/><title>{v}</title>";
In file included from C:\Users\Marcin\Desktop\8266kod_v1\8266kod_v1.ino:5:
C:\Users\Marcin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:39: note: previous declaration 'HTTPMethod HTTP_HEAD'
47 | enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
C:\Users\Marcin\Desktop\8266kod_v1\8266kod_v1.ino: In function 'void callback(char*, byte*, unsigned int)':
8266kod_v1:11:13: error: 'D2' was not declared in this scope
11 | #define LED D2
C:\Users\Marcin\Desktop\8266kod_v1\8266kod_v1.ino:40:20: note: in expansion of macro 'LED'
40 | digitalWrite(LED,HIGH);
11 | #define LED D2
C:\Users\Marcin\Desktop\8266kod_v1\8266kod_v1.ino:44:20: note: in expansion of macro 'LED'
44 | digitalWrite(LED,LOW);
C:\Users\Marcin\Desktop\8266kod_v1\8266kod_v1.ino: In function 'void setup()':
11 | #define LED D2
C:\Users\Marcin\Desktop\8266kod_v1\8266kod_v1.ino:57:11: note: in expansion of macro 'LED'
57 | pinMode(LED,OUTPUT);
exit status 1
Ten raport powinien zawierać więcej informacji jeśli w
File -> Preferencje zostanie włączona opcja "Pokaż
szczegółowe informacje podczas kompilacji"
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <DHT.h>
#include <PubSubClient.h>
#define DHTPIN 5 // Digital pin connected to the DHT sensor
#define LED D2
// Uncomment the type of sensor in use:
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
unsigned long previousMillis = 0;
unsigned long interval = 10000;
const char* mqttServer = "192.168.0.81";
const int mqttPort = 1883;
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived in topic: ");
Serial.println(topic);
Serial.print("Message:");
String message = "";
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
message+=(char)payload[i];
Serial.println("-----------------------");
if(String(topic)=="LED"){
if(message=="LED ON"){
Serial.println("LED IS ON");
else{
WiFiClient espClient;
PubSubClient client(mqttServer, mqttPort, callback, espClient);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset saved settings
// wifiManager.resetSettings();
//set custom ip for portal
//wifiManager.setAPStaticIPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//fetches ssid and pass from eeprom and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
wifiManager.autoConnect("AutoConnectAP");
//or use this for auto generated name ESP + ChipID
//wifiManager.autoConnect();
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
dht.begin();
client.setServer(mqttServer, mqttPort);
client.setCallback(callback);
while (!client.connected()) {
Serial.println("Connecting to MQTT...");
if (client.connect("ESP8266Client" )) {
client.subscribe("LED");
Serial.println("connected");
} else {
Serial.print("failed with state ");
Serial.print(client.state());
delay(2000);
client.loop();
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
// save the last time you updated the DHT values
previousMillis = currentMillis;
float t = dht.readTemperature();
float h = dht.readHumidity();
if(!isnan(h)&&!isnan(t)){
Serial.println("Temperature : " +String(t));
Serial.println("Humidity : " +String(h));
String toSend = String(t) + "," +String(h);
client.publish("data",toSend.c_str());
what is causing this issue ? how can i repair this ?
