and i'm making my V2 of my first project
the V1 was a classic esp32 with dh22 sensor witch send via mqtt the temperature to a database
it work fine so I wanted to make more sensor, so I bought some lolin D1 mini and dht22 shield.
but when I tested the temperature were wrong so I thought that were cheap shield and no official lolin shield.
so I decided to buy some sht30 shield and I have the same probleme the temerature are wrong again. and unfortunatly the difference between the good and the "bads" sensor look not to be constant
I'm trying to evaluate the difference between the good temperature from the original esp32 and the 2 other sensor
the lolin dht22 is at least 6 °C over the esp32 dht22.
I don't know if there is a way to calibrate.
I put quite the same code (micropython) in the esp32 and the lolin and I don't know if it's a bad idea! because of some build in resistor which can disturb the sensor results.
Thank for who take the time to read my interrogations
by the way, excuse my broken english!
