Error downloading http://arduino.esp8266.com/stable/packa ... index.json
and there are no ESP8266 boards available to choose in the drop-down menu.
Until now, it has been working fine for months.
Anyone else see this?
Appreciate any advise.
Explore... Chat... Share...
flisterfive wrote:opening "%appdata%\local\arduino15\staging\packages\" and for each error downloading given in the arduino IDE, i downloaded the ZIP file manually, and copy to the above directory, after the fifth zip was copied. all was fine.
altanvid wrote:All of a sudden Arduino IDE (v1.6.12) is reporting:
