By alexmoorephoto
#94904 Hi All, I have seen a lot of debouncer codes available for Arduino but less that are compatible with ESP8266. I am still very new to it all which can mean that even testing these codes can be confusing. I have a sketch that sends an IFTTT notification via Webhooks when a button is pressed. I want to adjust this so that the code only runs if the button (actually a switch) is held down for 20 seconds. I have tried two approaches. One using EZButton for Arduino (may not run on esp8266?) and one using a more universal code from Danixu (original from Xoseperez). One of the things I am struggling with is how to string these example codes, and my existing code together. My original code was running entirely in Setup, but I believe we want to change that now that we are introducing the debounce function. Can anyone tell me which, if any, of these should work? I am not getting the desired results and worried it could be an error in the coding.
Original code (tested and works but gets repeat triggers):
Code: Select all#include <ESP8266Webhook.h>
#define wakePin 16
#define _SSID "xxxxssid"      // Your WiFi SSID
#define _PASSWORD "xxxxpw"  // Your WiFi Password
#define KEY "xxxxwhkey"        // Webhooks Key
#define EVENT "xxxxevent"      // Webhooks Event Name
Webhook webhook(KEY, EVENT);    // Create an object.
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(1000);
  // Connect to WiFi
  Serial.print("Connecting to: ");
  Serial.println(_SSID);
  WiFi.begin(_SSID, _PASSWORD);
    Serial.print("-");
  Serial.println("");
  Serial.println("WiFi Connected");
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  digitalWrite(LED_BUILTIN, HIGH);
  // Trigger without any value and get response.
  int response = webhook.trigger();
  if(response == 200)
    Serial.println("OK");
  else
    Serial.println("Failed");
    ESP.deepSleep(wakePin);
  // Nothing
EZButton code:
Code: Select all#include <ezButton.h>
#define KEY "xxxxwhk"        // Webhooks Key
ezButton button(16);  // create ezButton object that attach to pin 16;
  Serial.begin(9600);
  button.setDebounceTime(20000); // set debounce time to 20 seconds
  button.loop(); // MUST call the loop() function first
  if(button.isPressed()) {
    Serial.println("The button has been pressed for 20 seconds");
  WiFi.disconnect();
  delay(1000);
  // Connect to WiFi
    Serial.print("-");
  Serial.println("");
  if(response == 200)
  else
Buttondebouncer code:
Code: Select all#include <Arduino.h>
#include <ButtonDebouncer.h>
#define BUTTON_PIN              16
#define CUSTOM_DEBOUNCE_DELAY   20000
// Time the library waits for a second (or more) clicks
// Set to 0 to disable double clicks but get a faster response
#define CUSTOM_REPEAT_DELAY     0
ButtonDebouncer * button;
    Serial.begin(9600);
    button = new ButtonDebouncer(BUTTON_PIN, BUTTON_PUSHBUTTON | BUTTON_DEFAULT_HIGH | BUTTON_SET_PULLUP, CUSTOM_DEBOUNCE_DELAY, CUSTOM_REPEAT_DELAY);
    WiFi.disconnect();
    delay(1000);
    if (unsigned int event = button->loop()) {
        if (event == EVENT_RELEASED) {
            Serial.print("Count : "); Serial.print(button->getEventCount());
            Serial.print(" Length: "); Serial.print(button->getEventLength());
 // Connect to WiFi
    Serial.print("-");
    Serial.println("");
  if(response == 200)
  else
