I'm just switching from the Arduino IDE to VSCode/PlatformIO.
I have problems to find the right libraries again.
In the Arduino IDE I had added the json path to the addition boards manager URLS and had access to e.g. the library "https://github.com/esp8266/Arduino/.../libraries/ArduinoOTA".
Under PlatformIO I selected a new project with "Wemos D1 R2 (Mini)" and Arduino framework. Basically I can compile and flash. Unfortunately PlatformIO does not find the headerfile "ArduinoOTA" when I add it in the code.
I can search and include "ArduinoOTA" via the PlaformIO libraries search. But this is a different library with different function calls (ArduinoOTA from Arduino v1.0.9) and not from http://github.com/esp8266 (ArduinoOTA from Ivan Grokhotkov, v3.0.2).
How do I include the libraries https://github.com/esp8266/Arduino/ correctly on PlatformIO ?
Thanks
EDIT: Seems it was a local configuration problem. Everything is working now.
