Chat freely about anything...
By douwebakker
#95402 Good evening, may I introduce myself first? My name is Douwe Bakker, 72 years old and I live in Vledder Netherlands. My hobbies are electronics and during my working life I also earned my living there as a self-employed person.
Because I don't have a good command of the English language, I use Google translate.
Lately I've mainly been working on microprocessors.
I bought some ESP8266-01 and wonder if they are original. When I give an AT command there is usually no response. In a few cases the system time appears, but not an OK as you might expect.
Programming is also difficult. Often it doesn't work and an error message appears.
File "C:\Users\DiteQ Europe\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/DiteQ Europe/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/DiteQ Europe/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
Failed uploading: uploading error: exit status 1
Once in a while it works without changing anything on the sketch.
I also have other modules such as the HUZZAH feather and various ESP32 boards, and I don't have those problems.
What do you think could be the cause?
Greeting,
Douwe
