Using the new Arduino IDE for ESP8266 and found bugs, report them here
By giannis99
#96166 Hello,
I bought a ESP8266 LoLin new NodeMcu V3 recently for a uni project with the ch340g.
I am having trouble to upload. I am up to date with the drivers and also with the firmware.
I also checked with the AT commands AT and AT+GMR.
"20:12:18.150 -> AT
20:12:18.150 ->
20:12:18.150 -> OK
20:12:19.462 -> AT+GMR
20:12:19.462 -> AT version:1.1.0.0(May 11 2016 18:09:56)
20:12:19.462 -> SDK version:1.5.4(baaeaebb)
20:12:19.462 -> compile time:May 20 2016 15:08:19
20:12:19.462 -> OK
The code that i am trying to upload is the simple blinkwithoutdelay from examples.
The error is
"A fatal esptool.py error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, '��� ������� ��� ����� ����������� �� �� ������� ��� ����������.', None, 31)".
I looked and did many things that's being said in previous posts and in yt or arduino forum but with no luck.
. Variables and constants in RAM (global, static), used 28088 / 80192 bytes (35%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1496 initialized variables
╠══ RODATA 920 constants
╚══ BSS 25672 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 59667 / 65536 bytes (91%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 26899 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 231796 / 1048576 bytes (22%)
╚══ IROM 231796 code in flash
esptool.py v3.0
Serial port COM1
Thanks in advance..
