Using similar names to the existing SD.h and then relying on namespaces seems like a bad design idea to me. I'd have assumed it was to allow existing code to swap over, but as the APIs aren't identical that presumption doesn't seem quite right either.
I need to look deeper. What I posted is however a decent workaround.
martinayotte wrote:That is the commit done 4 days ago, it is merged.
Maybe there are no conflict between FS.h and SD.h, but SdFat is a completely different library, much more better than the old SD.
But the issues is having both FS.h and SdFat.h included, there still some clash of having 2 kind of "File" class definitions, the one from SPIFFS is tiny, and the other provided much more to support FAT filesystem.
Probably IGRR will need to look at it ...
Hi you are discuss this topic in adruino。
do you know how to init spiffs in RTOS,when first using?
i mean how to set the flash address , i using ESP-01 1MB flash IC
BR!
