- Fri Dec 18, 2015 3:20 pm
#36736
First, it is impossible for the two ESP AP to connect each other, APs are not connected to anything, they waiting for STAs to connect.
As I said, I doubt you will ever find such devices on the market, there are no needs for that.
Maybe you can explain in more details what you are trying to do, maybe even with diagram, because it is not obvious.
So, if 2 ESPs together is not a solution, maybe a RaspberryPi (or other small Linux board) with 2 Wifi USB dongles and iptables foward rules will be another solution. But again, I need details of the goal.
Edit : when I'm asking you details, it is because even with you first description, the case is not obvious. Do you mean that any users on left side can do file transfer to any of the users on right side ? Networking isn't so simple, bridging two networks can becomes a mess if not handle with proper routes and iptables rules. If User1 and User2 is an hardcoded path, the the 2 ESP solution can still be apply, but it is NOT a network bridge, it is a Serial bridge between to networks.
(In other words, User1 can not ping User2)
