Normally, blue LED is the ESP TX, so if you are sending something and it light up, this means you RX/TX should be crossed :
ESP RX <-> FTDI TX
ESP TX <-> FTDI RX
Explore... Chat... Share...
at2marty wrote:I went back to attempting communication with a Raspberry Pi and connected it as follows.
Reset on ESP to GND
No matter which terminal program I use, I still get the same result. The blue LED flashes when I try to send a command, but no response on the terminal.
TX on ESP to TX on Pi
RX on ESP to RX on Pi
Reset on ESP to GND
CH_PD on ESP to 3.3V
ESP GND to Raspberry Pi GND and external power supply GND
martinayotte wrote:Are you sure that TX/RX are connected properly ?
ESP RX <-> FTDI TX
ESP TX <-> FTDI RX
