By haroldjclements
#4316 I apologise for what is probably a simple question. I have (what I believe to be) a model 2 board (LED near the antenna). Now, I have connected the Vcc and GND to my 3.3v regulated PSU. I have connected also connected CH_PD to VCC. UTXD is going to RX on the TTL and URXD is going to TX on the TTL. All is connected and switched on. I am able to see the ESP wireless access point signal and my TTL is reporting as COM4 on my Windows 7 computer. I have also tried connecting the GND pin of the TTL to the GND of the PSU.
I open Terminal, with a Baud Rate of 115200, Data Bits 8, Stop Bits 1. Connect and I do not get anything response from the ESP (I have tried powering on and off the device).
The TTL works fine it I jumper the RX and TX together (echo).
Any help / pointers very much obliged.
Thank you in advance,
Harold Clements
By haroldjclements
#4340 Thank you very much for your reply, but alas no luck :cry:
I have also tried using the RX TX of my Arduino and use the Arduino serial monitor, but to no avail.
As I have said, I am a newbe so please excuse the ignorance of my questions. As the ESP is reporting as a WiFi access point (and can be connected) would that suggest that it is working 100% and it's something that I am doing wrong, or could it be that the serial communication part of my device is faulty?
Thanks again for your help,
Harold Clements
By alonewolfx2
#4345 you cant use arduino rx tx with atmega chip. if you remove atmega on board and try again propably it will work
