I'm adding the pin layout image I'm using as reference for support
thanks in advance for any help you could provide
Explore... Chat... Share...
/// notes
/// the esp12e USES qio FOR THE PROGRAM FLASH
/// the places GOPI10 and GPIO9 as unavailable
/// unless the flash inside the can is removed and pins 3 and 7 lifted
/// pin 3 is wired to 7 and then to 3.3v
/// pads 3 and 7 are connected to GPIO9 and GPIO10
/// since GPIO9 and GPIO10 are now free and then set the FLASH to DIO mode
//// QIO will now not work
/// DIO mode maybe is the default for the arduino IDE NodeMCU v1 12E board
/// _CS |1 8| 3.3v
/// DO |2 7| _HOLD
/// _WP |3 6| CLK
/// GND |4 5| DI
#include <Arduino.h>
const int led = 2;
const int SD2 = 9;
const int SD3 = 10;
void setup()
//gpio_init();
Serial.begin(112500);
pinMode(SD2,FUNCTION_3); ////GPIO on 9 and 10 is function3
pinMode(SD3,FUNCTION_3); ////GPIO on 9 and 10 is function3
pinMode(led, OUTPUT);
pinMode(SD2, OUTPUT);
pinMode(SD3, OUTPUT);
delay(1000);
Serial.print("chipid");
Serial.println(ESP.getFlashChipId());
Serial.print("chipsize");
Serial.println(ESP.getFlashChipSize());
digitalWrite(led, 1);
digitalWrite(SD2, 1);
digitalWrite(SD3, 1);
digitalWrite(led, 0);
digitalWrite(SD2, 0);
digitalWrite(SD3, 0);
