the one-wire pin high-impedance isn't causing your file load utility to
discard that line?
-John
Explore... Chat... Share...
PuceBaboon wrote:Are you sure that the in-line comment on the line where you're driving
discard that line?
giuliano wrote:Hi, this is very strange
Have you seen this power consumption table ? https://nurdspace.nl/ESP8266
ESP in deepsleep mode take about 10 mA and in standby mode take only 0.9 uA but standby mode is not implemented in lua api for now...
