How do you expect the AMS1117 to work? It needs a resistor pair to set the output voltage RTFM.
David
DAFlippers wrote:Adam,
David
Thanks that is the first time I have heard that, I will try however none of the tutorial I used when learning how to use it suggested that was required, this is the module. According to what I found you just connect VCC to VOUT.
http://www.ebay.es/itm/AMS1117-800mA-AM ... SwNSxVM~x4
But will check out your suggestion now.
