By CHERTS
#7504
ulko wrote:In existing user_config.h there is my ssid + PW but still says: 'no MYAP found'??
Edit the file C:\Espressif\examples\esphttpd\include\user_config.h in such a form:
#ifndef __USER_CONFIG_H__
#define __USER_CONFIG_H__
#define USE_WIFI_MODE STATION_MODE
#define WIFI_CLIENTSSID "MYAP" <----------------- Edit
#define WIFI_CLIENTPASSWORD "00000000" <----------------- Edit
#define WIFI_AP_NAME "ESP8266"
#define WIFI_AP_PASSWORD "00000000"
#define PLATFORM_DEBUG true <----------------- Debug log enable
#endif
After flashing the ESP in the console terminal you should see these messages:
ESP8266 in STA mode configured.
Wi-Fi mode: STATION
STA config: SSID: MYAP, PASSWORD: 00000000
Httpd init, conn=0x3ffeac84
You see these messages?
By CHERTS
#7531
I found a possible cause and fix the file wifi.c, a new file in the attachment, copy it to the directory C:\Espressif\examples\esphttpd\user\
By ulko
#7583
The new wifi.c seems to have no effect. But before I changed config.h as you told me - and now I get connection (station mode was STATIONAP_MODE???). Hurrah!!
But now back to my modified example 'esphttpd' I tried to make and flash file webpages.espfs. Using 'htmlflash' looks good (build and flash) but using browser only submits e.g. led.tpl. But there is no httpd -send back of webpage to browser. So I believe mkespfsimage is not correct. In new version 1.0.5 are 3 dir's 'mkespfsimage_...'.
Which of these has to be used??
Can you please describe the steps to build webpages.espfs??
Kind regards
Ulko
EDIT: debug output from loading dht22.tpl :
Con req, conn=0x3fff5158, pool slot 0
URL = /dht22.tpl
Is url index 3
Heatshrink compressed file; decode parms = b4
Con req, conn=0x3fff5410, pool slot 1
Temp = 2160 *C, Hum = 3300 %
Conn 0x3fff5158 is done. Closing.
By jnosky
#7621
ulko wrote:Hi cherts,
After endless trials with partly success (only webpages.espfs not OK) I'm now using version 1.0.5. with a modified version example 'esphttpd'. All compiling, linking and flash runs without any errror.
webpages.espfs also is built correctly and flashed.
In older versions I got connection via wifi to my router.
The problem now is that I don't get connection. Only the following messages:
Ready
mode : sta(18:fe:34:9d:eb:48) + softAP(1a:fe:34:9d:eb:48)
add if0
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
add if1
bcn 100
scandone
no MYAP found, reconnect after 1s
reconnect
scandone
reconnect
Other examples (Hello World, dht22) work correctly.
No connection with 192.168.4.1/wifi
Do you have any idea?? May be the wifi part is defect?? What is MYAP??
Kind regards
ulko
When I had this problem, flashing blank.bin fixed it.
